ALL WARNING LIGHTS ON?
Legacytuner
when i got my silver bullet out of storage and started it up the brake,abs,battery,stop lamp,lights came on its been acouple of days and they are still on i put new pads and rotors all the way around before storage and the battery is brand new and the brake lights work fine i cant figure out why they are on. has anyone had this problem before
Proud owner of a 1991 Silver 5MT
Gold wrx wheels,Straight Exhaust, DNA Boost Controler 12 Psi, Ngk's, De-Snorked, Carbon fiber hood scoop in the werks
1991 White 5MT(Sold to Friend), AKA BINFORD
"KEEP IT REAL, KEEP IT SUBARU"
I'd be suspicious of the alternator. may want to have it tested.
I had this problem on my SVX along with other owners. Like 777 said,it could be a bad alternator. I would start with cleaning up the altenator connections. That is what took care of the problem on my car. If that does not work it is most likely the alternator going bad.Legacy777 wrote:I'd be suspicious of the alternator. may want to have it tested.
petridish38
Use a meter. The battery's part of the circuit so either way it should kill the car to remove it. Am I wrong? I know older cars were wired in series.
No....don't ever remove the battery while the car is running......that's a good way to fry things.
The battery acts as a sink and filter to help smooth out the voltage spikes coming from the alternator. Remove it....and you lose that smoothing affect with the voltage.
Take the car to an autoparts store and have them test the alternator. SIMPLE!
I will however caution you that sometimes they may still show marginal or good when in the car. If you want a true test....take it out of the car and bring it into the store for them to test.
Legacytuner
