TPS issue?
BAC5.2
TPS issue?
Hmm, I was thinking about this today.
Could all of my problems be because of a bad TPS?
My car doesn't idle correctly, and it's either idling or at 2k, there is no real inbetween when it comes to throttle movement.
How can I test the Throttle position sensor?
If the TPS IS bad, would it throw a code? I find it incredibly hard to believe that my old IAC and the brand new one would be bad. The IAC should last the life of the car, or at least 1/2 the life. The odds that I got 2 bad ones in a row, is unlikely.
http://www.main.experiencetherave.com:8 ... sting1.jpg
http://www.main.experiencetherave.com:8 ... sting2.jpg
http://www.main.experiencetherave.com:8 ... sting3.jpg
throttle not closing ?
yes test the voltages but also look for the possibility that the throttle itself is not returning to closed position. When its doing the 2k bit, try to manually close the throttle further. If that makes a change, the throttle body may be gummed up, or the cable or pedal assembly is farked. See if pulling up on the gas pedal slows the idle. I once traced all the electronics in a car only to find the carpet was binding up the pedal
BAC5.2
Yea, what's weird is the erratic idle, it's never constant. Sometimes 1k, sometimes 2k, sometimes 1250.
I throw an IAC code, but that's weird.
Sometimes the car will "hang up" at 2250 or so and just hold there until I tap the gas again. It's really really weird.
Thanks Josh!
Thanks Josh!
TRY IT!
It can be super cheap and easy to swap out the whole throttle body for another, and see what happens.
It worked beautifully for me when I was having my Idle Switch code going off.
I skipped the TPS testing procedure and just did that, cuz I had a spare TB right there, and did not have a proper "thickness guage" anywhere.
My symptoms were a little bit different though:
Mostly just Very erratic RPMs during driving... a couple times it acted up while idling too... stalled once. Sometimes it ran perfect, but usually only for a few miles at a time.
Anyway... It was SO flippin' easy!
I pulled the TB off my spare N/A motor. Stuck it on the SS, cleared the codes... presto.. no more problems. It took all of 30 minutes.
Thanks AGAIN to all who helped me with that!!!!
Ignoring the invariably invaluable insight of Vrg3, I did not replace the TB gasket, because the one from my donor engine looked almost brand new, and popped off quite cleanly.
It's certainly worth a try... Junkyard TBs can't be too awful expensive...
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
BAC5.2
BAC5.2
legacy92ej22t
Did you have the faulty IAC replaced yet?
It would be killer if a new TB fixed your woe's Phil.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Phil - It doesn't look like it's on their price list, so it'd be up to their discretion. In my experience they're pretty generous on weekdays, so I would expect you'd pay around $15 or $20 maybe.
MK - Yes, it would be infinitely cheaper to test all the stuff, but you can't test everything... like if his throttle body is actually letting too much air through (like if maybe the sealant around the throttle plate is gone?).
