Time to re-torque the heads. What specs should I use? I torqued them by the book when I intalled them. The FSM doesn't list a number, just 90 degrees the another 90 degrees.
Second, what is the torque spec on the axle nuts? I had to remove one of my front axles this weekend (long story).
I feel bad for my shop light...poor thing feels my wrath everytime I get under my car. This weekends total: One dead shop light, one smashed flashlight....And I'm not even done yet:(
Head bolt torque specs??
92 Turbo Legacy 4EAT
02 WRX - lightly modded (Gone but not forgotten)
axle nut is like 120 ft-lbs or something like that. I'd have to check for the exact number
Matt Monson
- quasi-mod-o
Check the manual again for the heads. It lists a process where you tighten the heads to a certain lbs (25, IIRC) and the do the 90 degree+90 degree thing. And it is very important that you follow the criss cross tightening pattern they talk about or it may leak...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
- quasi-mod-o
There's a very strict procedure to use when tightening head bolts on these engines, essentially what you'll be doing is overtorquing the bolts to stretch them out a bit, then loosening them, then torquing them down to the correct amount.
petridish38 has done headgaskets before, as has THAWA, plus a Haynes manual should have decent procedures in it.
petridish38
I'm pretty sure that I remember reading somewhere that the bolts did not need to be re-torqued since you stretch them out during the torque procedure and then tighten them down.
EDIT: here it is
http://endwrench.com/images/pdfs/2.2Liter.pdf
on page 16 "2.2L Engine Reassembly" 5th bullet down
Not sure if you can trust that.... but that's what I read...
Andrew
EDIT: here it is
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
