octane?
greg donovan
octane?
Post by greg donovan »
well i am new to the turbo scene.
what octane can i run?
around here i can get 90 91 and 92. but no 93.
the car will see stock boost levels untill net summer at the soonest. even then it probably wont go over 10psi untill i add a intercooler.
oh, its a '94SS.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
I think Subaru specifies a minimum of 91 octane. At stock boost levels 91 will be fine. You might notice a little improvement with 92.
greg donovan
sounds good to me.
96 Impreza L sedan
00 Impreza RS sedan
BAC5.2
Post by BAC5.2 »
The higher the better.
I'd run C16 if it was cheap enough, and could be pumped directly into a car.
Oh, and if it didn't kill your engine...
dzx
Post by dzx »
If you get too high of an octane, it will actually hurt performance depending on how stock the engine is. 91-93 octane should be fine tho.
///M
'93 Legacy SS - part out
91White-T
Post by 91White-T »
91 is MORE than enough for stock boost. Besides, even if its shitty gas, the computer will pull timing to reduce any knock, which there will be none anyway.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
Brat4by4
Stratified
Post by Brat4by4 »
Run the highest you can get. It's cheap insurance. The extra cash per fillup is minimal and will be less than $100 per year. Our ECU's are very good about squeezing extra power out of good gas, I'd rather the car keep advancing the timing to make extra power rather than backing it off to save 60 pennies on a fillup. Plus, typically the higher grade is just better gas.
LegacyT
Post by LegacyT »
I've noticed even regular is more then enough for non agressive driving. And even when u give it a little spurt of power there is no sign off detonation.
Mark,
Subaru_Nation555
Post by Subaru_Nation555 »
I always use 93 octane. Its a little pricey but worth it.
'06 Impreza 2.5i wagon
legacy92ej22t
Post by legacy92ej22t »
I run Ultra 94 almost exclusively. The only time I don't is if I'm out of town and can't find a Sunoco or I'm at the track running GT-116 ! :twisted:
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
BAC5.2
Post by BAC5.2 »
When I hit the Dyno, i'll run race fuel. There is a place that sells it down the street from me. Maybe I should get a few gallons when I need to fill up next...
snowboarded
Post by snowboarded »
I use at least 91, because thats just the highest that most stations i find have.
Anytime i find the higher octanes I get them without question.
[quote="Manarius "]Only flamers will get those. [/quote]
[quote="All_talk "]How many WHP will that give me? :)[/quote]
2010 Subaru Impreza 5mt 5 door
The required octane needed will depend on elevation....even though it's less of an issue for turbo cars. 91 is fine.
