octane?
octane?
well i am new to the turbo scene.
what octane can i run?
around here i can get 90 91 and 92. but no 93.
the car will see stock boost levels untill net summer at the soonest. even then it probably wont go over 10psi untill i add a intercooler.
oh, its a '94SS.
oh, its a '94SS.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
The higher the better.
I'd run C16 if it was cheap enough, and could be pumped directly into a car.
Oh, and if it didn't kill your engine...
Run the highest you can get. It's cheap insurance. The extra cash per fillup is minimal and will be less than $100 per year. Our ECU's are very good about squeezing extra power out of good gas, I'd rather the car keep advancing the timing to make extra power rather than backing it off to save 60 pennies on a fillup. Plus, typically the higher grade is just better gas.
I run Ultra 94 almost exclusively. The only time I don't is if I'm out of town and can't find a Sunoco or I'm at the track running GT-116 !
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
When I hit the Dyno, i'll run race fuel. There is a place that sells it down the street from me. Maybe I should get a few gallons when I need to fill up next...
The required octane needed will depend on elevation....even though it's less of an issue for turbo cars. 91 is fine.
