15" wheels to 14" wheels = vibration
stant093
Voluntarily Dismissed
Post by stant093 »
so i just switched rims on a 95 legacy from 15" to 14" rims, also changed brake pads, now i get a vibration, feels almost like a wheel bearing would feel. rims fit no problem, and tires are matching size. any idea what could be causing this??
Did you have the wheels balanced after having the tires mounted on them? If so, is it possible one or more of the wheel weights fell off?
stant093
Post by stant093 »
yeah they were mounted and balanced, its not a shutter from high speeds, i took if for a ride about half a mile up a hill and then back, top speed maybe 25.....(roads are bad). so i dont think its a wheel weight....
Hmm... So you think maybe it's because of the brake pads? How did the rotors look?
You torqued the lugs properly, right? Made sure the threads on the studs and nuts were clean, straight, and dry, and tightened in a star pattern to around 70 lb-ft evenly?
My wheels do the same thing because they're slightly bent from sliding into curbs sideways. 8)
stant093
Post by stant093 »
vrg3 wrote:Hmm... So you think maybe it's because of the brake pads? How did the rotors look?
it might be the brake pads, dont know, the rotors look ok, they could use a good turn on a lathe, but i dont think theyre whats doing it. im leaning more on the tire wear on the tires, i mean, if i have 4 matching size tires, mounted and balanced, the sound wouldnt be anything getting damaged...i dont know...very odd
lugs are on perfectly, i have a nice tourqe wrench ;)
