HOW-TO flush ATF fluid
I've just bought my car and the ATF is black.
How do I go about flushing it and what fluid should I use? The local Subaru dealer said that I would need about 8L of Castrol TQ95.
Also, what should I use for the Front (Open) /Rear (Viscous LSD) diffs, Castrol EPX 80/90W?
Thanks in advance.
Thanks in advance.
John
http://www.cardomain.com/ride/560635
Whoever told you to use special LSD fluid needs a good punch in the face. The viscous LSD units are sealed, the lubrication is never supposed to get inside. Plain old dino can be used if you wish. I only suggest the Mobil because its low cost and easy to find.
I use redline D4 ATF in the transmisison and power stearing of one of my legacy.
Its not really possible to do a full flush except for the T-Tech machine I mention. Even if you remove the pan a good portion of thefluid is still inside the transmission and the TC. The machine at Jiffy lube uses about 20 quarts to dilute the system until little if any of the old fluid remains.
- Spelling Nazi
I used to hate rebuilding this poorly made gearbox we had at work because the smell would be on my hands for hours.
- Spelling Nazi
lol, i used to have that prob, but i cut my hair and have all access to a nice pit at my brothers garage now.....vrg3 wrote:My hair gets caught in the wheels of creepers, no matter how I try to keep it tied out of the way.
on another note, not to hijack your thread, whats everyones input on merceron (sp?) dexron III atf? i changed my tranny filter and fluid and used the moentioned fluid, but the at still hesitates...
- Spelling Nazi
