Similar forum for newer Legacy?
99_SUS_VT
Post by 99_SUS_VT »
Hey just stumbled across this site and see it has a lot of good info but little that seems to pertain to my wife's car.
It's a 99 Legacy SUS AWD 2.5 auto with 120k miles.
It's been exhibiting some suspension problems recently and i'd like to find a good source of info on what kind of things I should be looking at and replacing. Also keep in mind personally I know next to nothing about Subarus or imports for that matter.
Know of any good sources of info? TIA
1999 Legacy SUS stock with 20% tint all around
2002 Dodge Ram 1500 4.7/5spd
1988 Dodge Ramcharger 318/727
The legacy forum on nasioc is good for the newer legacies
http://forums.nasioc.com/forums
The USMB is good too http://ultimatesubaru.net/forum/
THAWA
Post by THAWA »
what is an SUS?
Sedan version of Outback.
I think it stands for Sport Utility Sedan. Not very common and most brochures I've seen don't even mention them.
THAWA
Post by THAWA »
oh right, those are HOT. I've only seen 2 here, on bd and one be, I wanted to take them both!
Yeah, I actually like them better than the wagons. Suspension wise the things to look for are bad bushings and joints. Jack it up and shake stuff, if it moves see where the play is coming from. Look at the rubber bushings for the antiroll bar links and mounts, control arms, etc. and see if they're deteriorated (it should be pretty obvious). Press the corners to test the shocks - it shouldn't bounce more than twice. My bet is the bushings are fine as it tends to be age that kills them, though mileage does come into play to a lesser degree. The most important things to check are the ball joints and tie rod ends as it's a safety issue.
