MRT Master cylinder bracket.
rally370
Post by rally370 »
I forgot to tell you that fitting the MRT bracket and braided lines made a big different to the brake pedal feel.Get someone to push the brake pedal while you look at the master cylinder and you be amazed how much it moves.
I fitted the bracket in about 30 mins but did have to drill the rear holes bigger to fit it.
Cheers
Chris
yeah....it's pretty crazy to notice how much it does move. Even with the brace on there it still moves a little.
wow 30 min.....took me much longer. None of the damn bolts would line up/start on the firewall.
Post by BAC5.2 »
Anyone got pics of the brace?
rally370
Post by rally370 »
It only took about 30 mins because I put the bracket there first and checked the holes.I noticed the two rears were not in line so I drilled the holes bigger.Job done
I also made my own clutch center tool with a piece of wood dowel through a 17mm socket,worked a treat.
Thanks for the photo links.
Cheers
Chris
Post by BAC5.2 »
Josh, for some reason your website takes FOREVER to load pics on my computer. And it's only your site.
I STILL haven't seen the shift linkage install pics :(
hmmm
They are on my personal server, so that may be why it takes longer. What internet connection speed do you have?
Post by BAC5.2 »
College Ethernet...
totech
Post by totech »
BAC5.2 wrote:Josh, for some reason your website takes FOREVER to load pics on my computer. And it's only your site.
I cannot see them because of the port number - same as my proxy server
08 GE - SWP
96 BG - SGP
96 CX - EBP
Post by BAC5.2 »
Which means...
Try these. It'll give you a pop up about the certificate not matching, but you should at least be able to view them. You can do this for any of the links/pics I post. Change it to https and get rid of the 8080 port.
https://www.main.experiencetherave.com/ ... acket1.jpg
https://www.main.experiencetherave.com/ ... acket2.jpg
https://www.main.experiencetherave.com/ ... acket3.jpg
there's some various pics scattered in this page
https://www.main.experiencetherave.com/ ... egswap/09/
there's a pic from beneath on this page
https://www.main.experiencetherave.com/ ... egswap/10/
