Emanage Help
bluesubaru
Emanage Help
Post by bluesubaru »
I have installed the emanage and have the software and laptop. But my usb to serial or usb to usb connection for the comunication between the laptop and emanage doesnt seem to work. I cannot connect. I have com3 set on the emanage program, and it says its connected, but I cant import or export data.
Any help please?
-David
Most USB to serial adapters totally suck. I have a lot of experience trying to use actual RS232 devices with USB adapters, and most of them are ridiculously crippled. Basically, they're designed to cost almost nothing to manufacture and to HotSync a Palm Pilot.
You might ask other e-Manage owners what kind of adapter they use, but the best way to go in my opinion is a PCMCIA serial card with a standard UART (most commonly the 16550). Over the years I've probably sold two dozen of these on eBay, many to car owners who need to talk to their aftermarket ECUs but had bad luck with USB adapters.
Or just get an old laptop with a serial port.
bluesubaru
yeah people have mentioned to me old p2 laptops for a few hundred bucks. Ill wait for a reply from a few other forums first. Thanks.
95 Legacy N/A EJ22 - Turbo @ 5.5psi
WRX Turbo and Intercooler
STI Exhaust
TDGKORN
Post by TDGKORN »
Doesn't the support tool come with the right cable?
Let use know how you like the e-manage when you get it up and running.
92 legacy ss 4eat
bluesubaru
Yeah it comes with usb to 9pin serial cable. So i bought an adapter for it, my computer only has usbs and the 15pin and 25pin outlets for monitors and printers.
So I have it running, the install should have been easier if I had the right ecu pinout from the beginning.
So far all I have done is messed with the features and added a little more fuel to compensate for my intake/exhaust. I used to backfire a little bit, now not at all.
I am actually looking forward to tuning and having fun.
Thanks vrg3 for the help.
-David
TDGKORN
Post by TDGKORN »
I see,
Are you doing all the tuning yourself or are you doing any dyno tuning?
What kind of boost control are you using? I highly recommend the e-01.
92 legacy ss 4eat
dzx
Post by dzx »
I wasn't going to say anything but apparently piggybacks do work with these cars.
mine = s-afc and apexi itc.
///M
'93 Legacy SS - part out
bluesubaru
the e-o1 did look good, but I am not sure yet.
And why doesnt piggybacks work on these cars?
STI Exhaust
TDGKORN
Post by TDGKORN »
Some people are convinced that piggybacks won't work on our cars.
Even though they have never tried any.
92 legacy ss 4eat
JasonGrahn
Post by JasonGrahn »
The E-manage is a very capable unit. I've seen one installed on a civic with a custom turbo application. Good luck with the process.
Am i correct in understanding that both USB/Serial AND USB/USB cables are not working with the e-manage to your laptop?
if neither cable works, I would double check the connections on the computer and the connections on the emanage.
-Jason Grahn
bluesubaru
No it connects now, I had to get an adapter.
STI Exhaust
dzx
Post by dzx »
The guy that runs tarmac usa, his younger brother had a legacy with a T3/T4 Garrett turbo and was using piggy backs. I think he said it dynoed 419hp at the front wheels @ 18psi with the fwd fuse put in.
///M
bluesubaru
wow that is real nice numbers. Piggy backs are good, stand alones are better but for what I am doing, i dont need that.
STI Exhaust
illnastyimpreza
Post by illnastyimpreza »
dzx wrote:... I think he said it dynoed 419hp at the front wheels @ 18psi with the fwd fuse put in.
doesn't that totaly fuck up your transfer case?
It's all about the power to wait ratio
98 Impreza RS
91 Legacy L wagon
THAWA
Post by THAWA »
He doesnt have a transfer case...
