Scary Fast
Scary Fast
I finally finished my FMIC and worked out most of the bugs i was having with it. I have to say there is a huge difference. Running at the same 12psi on the 16G that i was before, it pulls way harder. So hard that i get nervous just thinking about stepping on the gas pedal too hard. There is almost no lag as my pipes are pretty much straight to the intercooler in as short a distance as possible and not too many bends. To give an idea of how quick it is, with the mods done to it, it will pull on a stock wrx like its standing still I've never been scared of driving fast cars but i get butterfly's when the boost gets above 10psi on this car. I'll have some pics in the picture forum soon for those that are interested.
///M
'93 Legacy SS - part out
holy crap!. Looking at your mods your car must be a crazy beast!
You also got the 4.11 gears! Wow, I can't imagine.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
The intercooler piping wasnt that difficult when i finally got the time. First thing i did was move the battery to the trunk. I still had 2 guage wire run for my amp that got stolen so i just hooked it up to that and grounded the negative. Then i moved the horn and drilled a hole where it was just behind the headlight, same with the other side except did the coffee cup mod there with a little duct tape to help it out until i find something more permanent.
Oh yeh, the piping i used stainless steel with aluminum bends held together with silicone and clamped. I'll probably replace the aluminum bends cause they tended to bend a little when i clamped them. I would recommend using a wrench to tighten the clamps rather than a screw driver if you go this way. I found out that a screwdriver doesnt get it tight enough and kept blowing the pipes off the intercooler which was a real pita.
///M
I'll second using a wrench instead of a screwdriver when tightening those style of clamps. When I replaced my radiator hoses, the lower one wasn't tight enough and it leaked...slowly... It took me a while to figure out why the hell my coolant reservoir was empty after a day or two driving around
-Brian
-Brian
'04 PSM FXT
Do a problem-free contest and see who wins.
- Title Whore
- quasi-mod-o
I've heard it in person. It sounds like a snarling evil boxer powered beast of a leggy...legacy92ej22t wrote:Sounds killer! Can't wait to see the pics.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
I really need a straight pipe and a fmic.
What are the dimensions of the spearco core, and did you have to cut the bumper beam?
