Apparently, my engine isn't getting any fuel.
I pulled the outlet hose from the fuel filter and turned it over and no fuel came out.
I haven't tried it with the inlet hose yet.
I may have to replace the fuel pump.
If I do, is there a good, relatively inexpensive upgrade for our pumps?
Apparently it isn't getting fuel.....
Rio Red '91 Legacy SS
- Title Whore
Is it straight-up drop-in, or just about?
Got a site that has it so I know just what to look for?
anyone know how much a replacement regular fuel pump would be?
- Title Whore
dunno.. but the walbro runs about $80-$85.. not too bad.. OEM, which DOESN'T flow up to 255lph is probably somewhere different...
Yes, its a drop in, if you get the right model.. otherwise, there's some wiring issues.. ask Douglas.(douglasvincent) or even Phil, BAC5.2
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
check the fuel pump connector under the seat and verify you have power.
- Title Whore
