Switch in the dash
jpoyann
Switch in the dash
Post by jpoyann »
I want to install a secret switch in the dash of my Legacy Turbo 2.0.
When the switch is on, the car can not be turned on. When the car is on and the switch is passes from off to on, the car turns off.
Witch cables in the ignition may I use?
If I want to put it in the motor compartment. Witch cables can I use?
Thanks for the help!!!
Jose Poyan
Subaru Legacy 2.0 Turbo 4WD Sedan
The most obvious wire to use in the dash is the red wire of the ignition switch. This is "ignition" wire.
It would be pretty easy for a thief to find, though. A thief is likely to be looking at those wires anyway.
It may be a better option to interrupt the wire that the ECU uses to control the fuel pump relay. It is pin 23 of the 26-pin connector of the ECU. These pinouts should be close enough to your car:
http://www.graphics.cornell.edu/~v/ecupins/
In the engine bay, one option is to interrupt the ground wire of the ignitor. On the right strut tower there is a bracket holding a sensor and a couple of solenoids. On the back of the bracket is the ignitor. The ignitor has a 5-pin connector and a 4-pin connector.
The 5-pin connector looks like this (when looking into the ignitor):
Code: Select all
 ____| |____
| 5 4 3 2 1 |
|___________|
Pin 5 is the ground. The wire should be black.
jpoyann
Post by jpoyann »
In the ignition you want to mean to interrupt the red wire, or put it to ground?
Thanks for the link to ecu, vrg3. It´ll be very helpfull for me!
Do you know how much time does it take to the car to stop when interrupt the fuel pump relay?
Interrupt it! But, really, it is better to use the fuel pump relay wire. The red ignition wire carries much heavier current.
The car should run for an absolute maximum of about 5 to 10 seconds without the fuel pump if it is idling and the engine is warm. Usually it will not run at all though. And if you try to move the car it should die immediately.
jpoyann
Post by jpoyann »
I´m agree. I´ll use the fuel pump wire, because it seems to be the best option. I´ll not use the red wire ignitor, but I´ll put a second switch in the motor bay for the ground wire, because it´s very easy to install as I saw, and I need extra security (the car sleeps outside). Do you have idea of the current for that wire?
Do you know where is the car speed signal pin ? I can´t find it in the link to ecu! (I´m thinking to install a Basis Head Up Display in my Subaru! Thank again.
The ignitor ground wire does carry fairly heavy current -- perhaps 10 amps.
The pin labeled "VSS" in my pinout chart is the vehicle speed sensor.
jpoyann
Post by jpoyann »
Thanks a lot vrg3. I´ll start working in my car!
