My car was on a semi-flood....
lleiro
Post by lleiro »
Hi Fellas,
I need some help if possible. My wife got stocked in the water yesterday due to heavy rain here in SC. Water got up to let's say 3/4 of the wheels...
She drove the car for 15miles after that and then stops all of a sudden not been able to start the engine again.
It cranks but doesn't start. Been familiar with computers more than with cars I took off every fuse to try to isolate the problem, but I need to know which fuses or relays I should let on to do my trial.
Any other ideas will be highly appreciated. Thanks.
BTW.... it is a 95 Subaru Legacy Brighton (Wagon)
Manarius
Post by Manarius »
Did it get wet inside the car?
lleiro
Post by lleiro »
Yes a couple of inches that we took off today...
She shouldn't have drive it but I gues but if I was there I may have done the same... :roll:
scuzzy
Post by scuzzy »
do all of your dashlights come on like normal?
IIRC, the ECU is in the floorboard of the passenger seat - if water got in the car, you're screwed - please correct me someone if I'm wrong, it may be in the dash, but i thought it was in the floorboard.
taking it to a mechanic is probably your best bet.
#82 M4 TRSCCA Rallycross
The ECU is up under the dash.
The controller under the pass seat is the ABS ECU.
