Oil pump to block o-ring (pictures)
tychl
Post by tychl »
When searching the archives for the o-ring part number, I came across two PNs, 10991AA001 and 806919050. I wasn't sure which one was correct, so I ordered both to be on the safe side.
They'll both work, but I like 10991AA001 better since it has an extra sealing edge.
Ignore the paper towel dust, I'll clean up before actual assembly! :-)
206er
Post by 206er »
best first post evar :)
tychl
Post by tychl »
Thanks! I figured I should give a little something back for all the help I got out of the archives for part numbers and procedures for both the timing belt/oil pump and suspension parts.
I'd like to thank Legacy777 for the timing belt replacement pictures, I was somewhat hesitant to pull the oil pump to fix the oil leak that was developing, but after I saw pictures I knew it'd be cake, took about 30-40 minutes from popping the hood to oil pump on the bench :-D
(I've done 2.3NA 5cyl / 2.7t V6 audi timing belts before, takes 30 minutes to get to the timing belt covers, well, a little quicker on the 5cyl, still more work than the subaru :-) )
Welcome for the pictures :)
