I did it!
Locked
Marc Basiliere
I did it!
Post by Marc Basiliere »
Well, several weeks on, I've gotten as far into my 90K tune-up as I expect to. I replaced the fuel filter (w/Bosch), pulled some manky looking "Autolite" plugs out, installed NGK "V-Power" plugs, and installed a K&N filtercharger. My 93 5-speed TURBO sedan is running better and maybe even sounding a little better! Thanks for the pointers- they made replacing the plugs and fuel filter doable for a guy who had never even changed his own oil (the local oil&filter change is only $14- no labor charge!).
Now, does anyone have any recommendations for reasonably-priced performance rotors? Mine are in pretty rough shape (thanks, I think, to improperly torqued wheels), and I'd prefer to upgrade rather than replace worn parts when feasable.
Thanks-
marc
eGroups Sponsor
<http://click.egroups.com/1/9666/2/_/_/_/972358780/>
<http://adimg.egroups.com/img/9666/2/_/_ ... 8x602E.gif>
jason grahn
I did it!
Post by jason grahn »
>>>(the local oil&filter change is only $14- no labor charge!).<<<
let me think...
$4 for a Subaru oil filter -- $4
$1.25 per qt. of Mobil 1, 5 qts -- $6.25
I don't charge myself for labor....
soooooo... $10.25 for 20 minutes worth of work. 30 if i've been drinkin. And
it's fun. =)
J.
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
-------------------------- eGroups Sponsor -------------------------~-~>
eGroups eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/9698/2/_/_/_/972359411/
---------------------------------------------------------------------_->
matt scicchitano
I did it!
Post by matt scicchitano »
Where in the hell are you getting Mobil 1 for $1.25 a quart!!!?!!! Put a
case of it aside for me , would ya !!! ;^)
-Matt
eLerts
http://click.egroups.com/1/9699/2/_/_/_/972380793/
Josh Colombo
I did it!
Post by Josh Colombo »
YES, inquiring minds would like to know??? Is this just conventional Mobil,
or Synthetic? I know I can get the conventional stuff, which is pretty good
if you ask me, for like 99 cents.
Josh Colombo
jcc189@psu.edu <mailto:jcc189@psu.edu>
of beats and rhythm" - ME
-----Original Message-----
Sent: Tuesday, October 24, 2000 9:11 AM
To: BC-BFLegacyWorks@egroups.com
Subject: Re: [BC-BFLegacyWorks] I did it!
-Matt
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972386368/
Barrett, Sam
I did it!
Post by Barrett, Sam »
Don't get drilled. Get slotted. Everyone I have ever heard of with x drilled rotors have had to replace them earlier than a stock rotor.
Sent: Monday, October 23, 2000 8:35 PM
Subject: [BC-BFLegacyWorks] I did it!
Thanks-
marc
eGroups Sponsor
<http://click.egroups.com/1/9650/2/_/_/_/972402644/>
<http://adimg.egroups.com/img/9650/2/_/_ ... 8x602E.gif>
Alan Croxford
I did it!
Post by Alan Croxford »
I had the rotors turned and new factory pads replaced about 3500
miles
ago and a few are warped already hadn't thought of torque on the lug
nuts? Seems that a lot of people have different ideas on what rotors
to use the last I heard was that Xdrilled would not warp but didn't
last as long. I could live with this if it is true. One thing I did
hear about was that some dealers of Ford and Jeep turn the rotors on
the car. The wheel is removed and a machine is fastened to the
suspension and to the spindle and a grinding wheel device grinds the
rotor from outer edge to the inner edge on both sides seems to me
that
this would be a good method and might even cost less. Anyone else
heard of this?
x
drilled
> From: Marc Basiliere [mailto:mtnboy@s...]
expect
a
K&N
maybe even
replacing the
his own
performance
improperly
parts
> when feasable.
> Thanks-
> marc
> eGroups Sponsor
<http://adimg.egroups.com/img/9666/2/_/_ ... Sports468x
602E.g
> if>
eLerts
http://click.egroups.com/1/9699/2/_/_/_/972406307/
Barrett, Sam
I did it!
Sounds ghetto to me. I mean think about it. If the rotors warp and a machine just grinds the outer surfact flat, that doesn't set them straight symetrically. It just leaves you with a 2 flat surfaces. I'll have to look at my rotors when I get home to confirm my theory. If your rotors are just solid discs it might work just fine. But if your rotors have spacers of any kind between the surfaces I know for a fact that method wouldn't work. Interesting. I'll look into this when I get home.
-Sambo
From: Alan Croxford [mailto:acroxford@hypermall.net]
Sent: Tuesday, October 24, 2000 9:48 AM
Subject: [BC-BFLegacyWorks] Re: I did it!
miles
that
heard of this?
x
drilled
expect
a
K&N
maybe even
replacing the
his own
performance
improperly
parts
> when feasable.
> Thanks-
> marc
> eGroups Sponsor
> < http://click.egroups.com/1/9666/2/_/_/_/972358780/>
< http://adimg.egroups.com/img/9666/2/_/_ ... Sports468x
602E.g
> if>
eGroups Sponsor
<http://click.egroups.com/1/9634/2/_/_/_/972406825/>
<http://adimg.egroups.com/img/9634/2/_/_ ... 468x60.gif>
Josh Colombo
I did it!
X-drilled WILL warp....I've done IT. If you want after market, get
slotted..
Josh Colombo
Sent: Tuesday, October 24, 2000 12:48 PM
miles
that
heard of this?
x
drilled
expect
a
K&N
maybe even
replacing the
his own
performance
improperly
parts
> when feasable.
> Thanks-
> marc
> eGroups Sponsor
602E.g
> if>
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972407617/
Alan Croxford
I did it!
What they were talking about was a method that would use the spindle
on the car rather than a spindle on the machine as a reference point
when grinding to true the rotors this would make a more accurate
surface on both sides. I can see where this could be true but I am
also wondering if it is such a good idea why aren't more makes or
dealers be doing it?
a
machine
to look
are just
spacers
of any
work.
> -Sambo
> From: Alan Croxford [mailto:acroxford@h...]
> miles
lug
rotors
on
the
> that
> heard of this?
> x
> drilled
I
> expect
looking
> a
> K&N
> maybe even
> replacing the
> his own
> performance
> improperly
worn
> parts
> > when feasable.
> > Thanks-
> > marc
> > eGroups Sponsor
> <http://click.egroups.com/1/9666/2/_/_/_/972358780/> >
> 602E.g
> > if>
> eGroups Sponsor
> <http://click.egroups.com/1/9640/2/_/_/_/972406316/>
<http://adimg.egroups.com/img/9640/2/_/_ ... ealth468x6
02F.gi
> f>
eLerts
http://click.egroups.com/1/9699/2/_/_/_/972438478/
John Gillon
I did it!
Post by John Gillon »
Yes, facing the rotors in place using the cars own power to turn the
rotors, is a common procedure... particularly for FWD vehicles,
possibly some 4WD vehicles... and would probably work on a Sub AWD...
I think!
John Gillon
--- In BC-BFLegacyWorks@egroups.com, "Alan Croxford" <acroxford@h...>
> miles
lug
rotors
on
the
> that
> heard of this?
> x
> drilled
I
> expect
looking
> a
> K&N
> maybe even
> replacing the
> his own
> performance
> improperly
worn
> parts
> > when feasable.
> > Thanks-
> > marc
> > eGroups Sponsor
> 602E.g
> > if>
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972482406/
Locked
