ej22t with a manual
theboyo19
ej22t with a manual
Post by theboyo19 »
so im doing an engine swap to get an ej22t out of an automatic 93..i was wondering if i need to change the ecu to run a manual tranny ? its going into my 95 BD
MPtyza
Post by MPtyza »
You can use the same ECU, the only difference between manual and auto is that the autos had a TCU, but the ECU is exactly the same for the EJ22T
Post by 555BCTurbo »
You will need to snip the ECU ID wire...that is it
You may need to mess with the positive leads for the cam & crank sensors....depending on what wiring harness you are using.
theboyo19
Post by theboyo19 »
do i need the ej22t ecu or can i use my ej22?
BSOD2600
Post by BSOD2600 »
IIRC, one must use an EJ22T ECU since they are different.
'11 WRX Limited
'94 TW | R.I.P.
BSOD2600 wrote:IIRC, one must use an EJ22T ECU since they are different.
Correct you are...
Unless your name is Doug Vincent... :lol:
