i rewired/ cleaned the engine bay wireing up alot. most of it was just rerouting and new wireloom. well when i did this i got a cel and if you blipped the throttle the car would bog horribly and almost die. i was freaking out and trying to figure out what the problem was in the engine bay and couldnt find a damn thing (later i noticed that the problem was the tps and fixed the problem).
so i went onto the cabin area where the ecu was covered with the protector plate (that i covered because when i got the car nothing was really put back together). pulled it off looked at it for like 2 seconds and noticed that i must have pulled a couple connections apart (there were a few of them that were just electrical taped together
i traced the larger gauge black wire back with the blue connector into the engine bay and it actually goes to nothing. it looks like nate hacked it off awhile ago because on the other end of it the copper is oxidized and muddy. that being said i carfully pulled it out making sure not to mess with any of the other wires in the mess.
the white wire looks to goto the o2 sensor (not labled as non of the other wires that are disconnected are).
there is a larger gauge black wire that pigtails out of the ecu that i dont know what needs to be tapped into.
then there is a small cluster on the side oc the ecu that has 4 wires that are jumbled together. 2 have actual splice connectors 2 of them dont.
just looking at this and been screwing around with it trying to figure it out and reading and reading what he went through to frankenstein it together is driving be crazy and im seriously considering swapping out the wiring harness to an ej22t (from what nate told me it has a ej18 in it now with a turbo ecu and 93 turbo powerplant of course). if anyone can please please please help me out i would so greatly appreciate it. thanks in advance.
