I am new to this group and have a lot to learn...
My first question is on headlights and what to do about the hazing on
the lenses from the years of use. Is there a way to clean them or do
they need replacing? If so where is a good place to get new ones? Or
even better, are there Japanese or Euro spec units I could source
from somewhere?
Secondly, I was wondering if anyone has tried to convert the turn
signals on a 91 turbo into driving lights as they already have a
clear lens. Can the parking lights be rewired to also function as
turn signals? Appreciate any help!
Kevin
-------------------------- eGroups Sponsor -------------------------~-~>
eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/9699/1/_/_/_/974603880/
---------------------------------------------------------------------_->
Lighting on a 91 Turbo
I heard there is a glass polishing substance like T cut but you buy it from a jewellers normally
Jewellers Polish it's called you could try that I have not seen anything similiar in a car shop
cheers
John
----- Original Message -----
To: BC-BFLegacyWorks@egroups.com
Sent: Sunday, November 19, 2000 3:17 AM
Subject: [BC-BFLegacyWorks] Lighting on a 91 Turbo
from somewhere?
Kevin
eLerts
eGroups Sponsor
<http://click.egroups.com/1/9650/1/_/_/_/974654145/>
<http://adimg.egroups.com/img/9650/1/_/_ ... 8x602E.gif>
cheers
John
from somewhere?
Kevin
eLerts
eGroups Sponsor
Use a med/light polishing compound, turtle wax or No.7 are good. Then
get a clear coat polishing compound, then a cleaner wax. The sequential
steps will help remove the built up grime, and get rid of the scratches.
If you have a motorized buffer, it will work better. The only real
problem is that it seems to come back, not as bad, but it definitely
comes back.
Josh Colombo
jcc189@psu.edu <mailto:jcc189@psu.edu>
of beats and rhythm" - ME
-----Original Message-----
Sent: Saturday, November 18, 2000 10:18 PM
from somewhere?
Kevin
eLerts
http://click.egroups.com/1/9699/1/_/_/_/974670203/
comes back.
Josh Colombo
from somewhere?
Kevin
eLerts
