I willl be installing the GC coilovers with KYB AGX on a 91 SS....the coilovers include spring top hats.....
So I need to go buy 93-01 Impreza rear top mounts?
Is this correct....I'm just a little confused on the top hats vs top mounts...please clarify so I can go buy the parts at a junkyard over lunch
Top hats vs top mounts
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
How much do these run from a dealer? Anyone have a ballpark?
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
Nobody has them....sucks...my install day is ruined....
What is the reason that the stock ones will not work?
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
tried here? www.subarugenuineparts.com
test fit the rear upper spring perch to the legacy upper mount. Depending on what kit you ordered you should be able to use the legacy mt or a WRX rear mt.
ps. you can probably get a mt from GC . it is an aluminum disc that uses hard urethane bushings. only you have to sand about half an inch off the inside because of the way the tower is shaped. bout $129
(91 turbo sleeper to be)- RIP
I miss my legacy :(
I miss my legacy :(
