coilovers
nickk248
coilovers
Post by nickk248 »
I just purchased some used Buddyclub Racing Spec Coilovers from a 02+ WRX. I am wondering if i will need to modify these in any way to make them fit my 93 ss.
tris91ricer
Title Whore
Post by tris91ricer »
Search around, but. . No.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
nickk248
Post by nickk248 »
tris91ricer wrote:Search around, but. . No.
what do you mean by no
asc_up
Post by asc_up »
he's saying that 'no you won't need to modify anything'
nickk248
Post by nickk248 »
ok thanks.
jamal
Vendor
Vendor
Post by jamal »
you will have to change the rear strut tops to something that fits your car.
Also you will have a lack of negative camber all around.
tris91ricer
Title Whore
Good point, Jamal, but I'm gonna wager that he doesn't know or care about neg camber. The guy just wants coilovers. Good point about the strut top, I forgot that part.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
nickk248
Post by nickk248 »
Is there any way to gain back some negative camber. Also im not buying the coilovers to just slam my car if thats what you guys thought.
Post by 555BCTurbo »
nickk248 wrote:Is there any way to gain back some negative camber. Also im not buying the coilovers to just slam my car if thats what you guys thought.
You could use rear camber bolts or notch the coilover housings...
nickk248
Post by nickk248 »
Also i was wondering what rear strut tops should i use that will work best for these coilovers?
nickk248
Post by nickk248 »
where can i find rear strut tops that will fit the coilovers/car? also where can i get camber bolts at?
nickk248 wrote:where can i find rear strut tops that will fit the coilovers/car? also where can i get camber bolts at?
Ummm...the strut tops on your car will fit...
My rear camber bolts are Whitelines...so any Whiteline dealer
jamal
Vendor
Vendor
Post by jamal »
whiteline bolts have a huge markup. Ingalls or intrax or whatever are the same thing and much less. Just make sure they're the ones with an actual cam and not a little nub stuck on the side of the bolt.
jamal wrote:whiteline bolts have a huge markup.
I got mine for $10... :D
