mystery connector
mexicanzero
mystery connector
Post by mexicanzero »
so under the passenger headlight there is a small connector that is the same style as the black under dash connector for checking codes in the engine. i have no clue what it's for
it was originally unplugged and i have plugged it in and unplugged it various times and have not noticed any difference. it seems to be attached to all the headlight wires and goes in the same protective sleeves so it looks to be an original wire on the car.
i'm just curious as to what this wire does so if you guys could check to see if you have such a connector running behind the passenger headlight and if you can figure out what it does that would solve one of this cars mysteries.
thanks
-Alex
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
Not sure, is it a "water tight" connector or just like the one under the dash?
mexicanzero
nope nothing fancy not water tight and its only one wire i dont think i said that before. its just like the black connector under the dash.
i'll try and get the wire colour and match it up to a wiring diagram but who knows if that'll work
-Alex
My car has this to. I asked and it is supposedly to change the fan delay. It was mean't to be unplugged though just a FYI.
mexicanzero
fan delay? so it makes the fan come on when the engine is hotter or cooler than normal? weird why would we want that...
thanks though its good to know
-Alex
the_watts10
Post by the_watts10 »
you would want that just incase you dont want your motor to overheat i mean cause i dont
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
mexicanzero
i dont think you understood what i was saying...
my motor doesn't over heat the fan still comes on and the connector is disconected but if you conect it i guess it is supposed to make the fan come on sooner than usual or later than usual, and so i said to that "why would we want that?" i wasnt saying why would we want the fan to run...
but yeah overheating sucks
joeWM
Post by joeWM »
mine was unplugged as well when i got mine, didnt think that was right so i plugged it in, leaving it at that
[quote="kimokalihi"]Jesus, that's a grocery list of problems.[/quote]
92 Legacy SS 5MT....sold :(
02 Aspen white WRX Stage 2, 20%tint
I did some looking into this the other day. I'm pretty sure it's the sub fan short connector.
The radiator fans have two sets of windings in them I believe. Only power one set of windings, you get a slower speed. Power both sets, you get a faster speed.
Without the AC system, the short connector should be connected as to power both motor windings.
With the AC system, there's some question as to whether it should be connected, and whether the fans should operate independently or not. With the sub fan short connector disconnected they will operate independently. With it connected, the fans will operate together.
The sub fan also is two speeds, and has a pressure switch built into the pressure switch on the AC receiver drier. When pressure raises too high, the sub fan will kick into the higher speed.
So yeah....that's what that connector is.
Here's a diagram
http://www.main.experiencetherave.com/s ... iagram.pdf
joeWM
Post by joeWM »
aw ok, makes sense now, thanks josh
Buffman
Post by Buffman »
Where do you plug it into?
1992 Legacy LS Special Wagon..
It should be jumpered.
Buffman
Post by Buffman »
hmm i just see it (single wire connector) and nothing else down there. Maybe it's been pushed out of sight.
Red with yellow stripe.
That's probably not the same connector as the fan connector.
Look at the diagram I posted, connector F2 and its shape to see if it matches what you're looking at.
Buffman
Post by Buffman »
found the other connector :) Connected it :)
and.....what did it do? Do both fans come on at the same time?
Buffman
Post by Buffman »
Have to get out there and check today.
94SS_Canada
Post by 94SS_Canada »
Yes i was wondering about this connecter, seeing how i dont have AC anymore i could have more cooling power then?
hmmm.
FastRust
Yes
