Taillight removal help?
SPUMONI_RT
I cannot get my tail lights out. I removed four 8mm nuts, each light assembly. Is there more nuts? Are the just stuck on? Thanks.
They're sealed on. Pull carefully or push evenly on the studs.
Yup. The sealant is a black gooey substance kind of like windshield setting tape or the stuff that holds the plastic covers over the doors behind the door panels. If you're careful with it you can just reuse it when you reinstall the lights.
