91 SS turbo "power" light flashes ?? help
antslegggy
Post by antslegggy »
hey, so every once and then ill hop into my car turn it on perfectly fine, but the little light in the middle of my console that says "power"blinks a bunch of times then stops, ive noticed no difference in the car when this happens, kinda weird, anybody had this happen and know what it means>'
?? thanks , taps.
DevC
Re: 91 SS turbo "power" light flashes ?? help
Post by DevC »
Its transmission related
I'm not sure what else triggers it, but mine flashed because there was electronic failure in my center diff causing it to be locked instead of active, this caused torq bind in low speed cornering.
93 Turbo Wagon, 5mt swap, vlsd, sti slanty, vf10, alk, subframe lockout, gr2's, sti sways.
96 F-350 CCLB Powerstroke
89 Volvo 244, lsx swap
That's letting you know there is an active fault and a code stored in the TCU. Here are instructions on how to retrieve the code.
http://www.surrealmirage.com/subaru/trans.html
TurnNburn
Post by TurnNburn »
I also had this problem but never figured out what caused it. I was curious about the fluid and found that trans pan gasket was leaking so i replaced that and filled it up with new fluid and the problem never happened again.
So i would at least check the fluid condiition and the level.
1990 NA 2.2 Open Light rally car
