synthetic oils
turbo970
synthetic oils
Post by turbo970 »
what are some brands do you guys like running
Re: synthetic oils
I use Shell Rotella
turbo970
Re: synthetic oils
Post by turbo970 »
has anyone tried the lucas brand
Alphius
Re: synthetic oils
Post by Alphius »
Shell Rotella T6. Full synthetic. Best value real synthetic out there. I run it in everything and it is awesome.
Re: synthetic oils
Mobile 1 full syn
Re: synthetic oils
Is the Rotella a diesel specific oil?
Re: synthetic oils
Alphius wrote:Shell Rotella T6. Full synthetic. Best value real synthetic out there. I run it in everything and it is awesome.
Is it significantly cheaper than mobil1? I've always used mobil1 but I don't think it makes much if any difference which synthetic oil you use so I might as well get something cheaper. Right now I'm spending about $28 for 5 quarts at walmart.
Alphius
Re: synthetic oils
Post by Alphius »
The Rotella is technically a diesel/gas oil, yes. It meets API certification for both.
T6 is the only full synthetic Rotella oil and is only available in 5W-40. T5 is semi-synthetic and available in more weights.
It is usually around $17-18 per gallon at Walmart.
Re: synthetic oils
Diiirt cheap. Come in 10w30?
Alphius
Re: synthetic oils
Post by Alphius »
T6 is only 5W-40. I don't know what the semi-synth T5 comes in.
Re: synthetic oils
Actually I can't remember which I've been using. Might be 10w40.
turbo970
Re: synthetic oils
Post by turbo970 »
well i have 500 miles to decide what brand to pick lol. i been thinking of royal purple. but my daugter's g pa told me to go with ams oil or something like that
Re: synthetic oils
I don't know about amsoil, but I had a problem with Royal Purple consumption (as in my car was "using" more than with other oils). That combined with the price made me not interested. YMMV though.
jefferson
Re: synthetic oils
Post by jefferson »
Been using Amsoil since back in the 70's. No issues with consumption which I have heard other brands have. I started out with Mobil 1 in a Z-1 that I had. Didn't like the way it escaped out of the engine. Heard and learned about Amsoil and have used it ever since. I even have it in my air compressor as they make an oil for that.
At work we had many issues with storm sirens and compressors in unheated hose towers that would trip breakers in the winter when they would try and run. Switched everything over to Amsoil and no more tripped breakers in the winter. Any synthetic probably would have done the same, but I will stick with Amsoil.
Jeff
turbo970
Re: synthetic oils
Post by turbo970 »
only down side theres only 2 amsoil dealers in my town.
tsbpenguin
Re: synthetic oils
Post by tsbpenguin »
Mobil 1 FTW. Consumption issues are issues with oil leaks, not the oil you're using ;) [edit: that is assuming you run a catch can]
In between Subies
