Engine Knocking
jmfpEJ22T
Engine Knocking
Post by jmfpEJ22T »
I have a 93 touring wagon with a jdm ej20g. Not too long ago i noticed my car was sounding different and maybe only running on 3 cylinders? It starts to shake when the rpms start to go back down after starting. I drove it around a bit and i noticed when it accelerates it knocks. This is quite scary and im just wondering what could be wrong with it.
alexandermf
Re: Engine Knocking
Post by alexandermf »
How loud is the knock? It could be anything from hydraulic lifters ticking to rod knock...
jmfpEJ22T
Re: Engine Knocking
Post by jmfpEJ22T »
its not too loud but i dont really have anything to compare it to..
robertpaige
Re: Engine Knocking
Post by robertpaige »
Post a video.
jmfpEJ22T
Re: Engine Knocking
Post by jmfpEJ22T »
Ok heres the deal. One day i started my car up and it ran perfectly and it hasnt done anything since. What could this be? Could the timing have been off?
robertpaige
Re: Engine Knocking
The knock your talking about may have been lifters? They can tick pretty loud and be mistaken as a slight knock and can come and go. A rod knock will never go away or fix itself. Does the car still shake?
James614
Re: Engine Knocking
Post by James614 »
Accidently put some 87/89 octane gas in it? My Touring Wagon got filled with 89 once and it knocked/shook quite a bit. Problem was gone as soon as it got filled with 93 again.
jmfpEJ22T
Re: Engine Knocking
Post by jmfpEJ22T »
No only 92 octane..
jmfpEJ22T
Re: Engine Knocking
Post by jmfpEJ22T »
the problem does sound alot like how you decribed with the shaking and knocking and then after revving it goes sub-500 rpm......
jmfpEJ22T
Re: Engine Knocking
Post by jmfpEJ22T »
could this be caused by a bad ecu because im trying to figure out whether i should get a robtune ecu or not because 380 is a bit much if its not going to fix anything.
robertpaige
Re: Engine Knocking
I doubt the ECU just went bad. Get the car running good before you do any modifications or tunes.
Is the issue still happening? or did you say that it went away..
Mister Anderson
Re: Engine Knocking
Post by Mister Anderson »
