-tear down
-clean and paint block
- replace all gaskets seals, and valve seals
- new waterpump, oil pump, hoses,new oil pan, updated seperator plate
- any other suggestions while apart?
I plan to use the whole 2.2 na intake and pcv setup, wirring, just swap it onto this block.
the turbo block has extra pcv ports 2 on the head and one more on the top of the block, just curious wwhat to do with these, can I omit them like the non turbo block?
what is a safe boost level on this lower compression engine?
t went yesterday. Time to get serious....
thanks its old ford blue
