Come on how about some help here???
Locked
Penty
Post by Penty »
Comeone guys I've only had a couple of replies ???????
I need some feed back pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!
cheero
¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,¤º°`°º¤ø,¸¸
Info: John Carlsson UK 92 Legacy 4 cam Turbo Estate
E-mail : penty@nettaxi.com
-----Original Message-----
Sent: 10 July 2001 124
To: 'BC-BFLegacyWorks@yahoogroups.com'
Subject: RE: [BC-BFLegacyWorks] Re: Urgent !!! Help! Help! Help! engine tr ouble
Oh my god! it would be great if thats all it is!!! can anyone recomend a flusher or oil in the UK that I can use to try and clean out the engine so it stops doing this!
thx again in advance
E-mail : penty@nettaxi.com < mailto:penty@nettaxi.com>
Sent: 09 July 2001 21:14
Subject: [BC-BFLegacyWorks] Re: Urgent !!! Help! Help! Help! engine
trouble
My car did that a while back, I just put in some
Marvel Mystery oil and drove around with it for a
couple thousand miles and the noise went away. Been
4-5 months now and the car sounds fine.
Subject: [BC-BFLegacyWorks] Urgent !!! Help! Help!
Help! engine trouble
It started about a week ago when I was driving along,
if I took my foot
of
the throtle down hills the engine started making a
tapping noise!!! If
I
revved the engine it would go away. I pulled in
straight away and
checked
the way and checked the oil level, which was fine. So
I drove home very
slowly and could keep hearing the tapping noise coming
and going as I
drove!!! I have now changed the oil filter and oil
aswell but the noise
seems to be getting worse and worse!! what can I do Is
my engine
damaged
some how ???
please help me I'm desperate there is no way I can
survive without my
car
and a second hand engine is going to cost more then I
can ever afford
(£1000)
I am waiting at my PC for you replys
thx sooo much in advance
Josh Colombo
Post by Josh Colombo »
As Dan mentioned too, I'm pretty sure it's an oil pump.
As for testing pressure. Go to your local auto parts store. See if they have a little pod gage or something like that for oil pressure. They usually come in a kit, with the lines, and tell how to hook it up. I have helped a friend do this on a big V8, but not any subarus. I'm not sure if the procedure is the same, but that is the only way I know how you could actually get a reading of the oil pressure. Other option, take it to a shop, and tell them you need to know what the oil pressure is.
Josh Colombo
jcc189@psu.edu
of beats and rhythm" - ME
Sent: Thursday, July 12, 2001 6:15 AM
Subject: [BC-BFLegacyWorks] Come on how about some help here???
cheero
trouble
if I took my foot
of
tapping noise!!! If
I
straight away and
checked
I drove home very
and going as I
my engine
damaged
some how ???
survive without my
car
can ever afford
(£1000)
sean john
Post by sean john »
Try Sea Foam, or Marvel Mystery. Those are the only
"snake oil" like products that I know of that's
supposed to clean out the inside of the engine. They
basically have petroleum distillates in them.
Date: Thu, 12 Jul 2001 11:15:19 +0100
Subject: Come on how about some help here???
cheero
$`0:$x,88,x$`0:$x,88,x$`0:$x,88,x$`0:$x$`0:$x,88,$`0:$x,88
<mailto:penty@nettaxi.com>
Help! Help! engine
tr
ouble
anyone recomend
a
so
<mailto:penty@nettaxi.com> >
<mailto:r32657@yahoo.com> ]
Help! engine
trouble
Locked
