Hi all,
I am on another list (Peugeot), and we are currently discussing the ideal
engine rebuild specs for the 2.2 L inline-4 in the 505 Turbo.
Since the Turbo Legacy is also a 2.2 L, it got me to thinking that it would
be neat to compare an inline 4 against the boxer 4 in terms of ideal engine
build spec.
Particular interst to me would be what your choice would be for the CR. The
one site had a guy totally rebuild the Suby 2.2 T with custom JE 9 :1
pistons for his plane...any thoughts on the pros and cons of running a high
compression high boost (13 psi) motor?
Is that an ideal or would you go low compression very high boost (15+ psi)?
I know peak power is higher with the latter, but what about driveability?
I'm after your thoughts on the ultimate Rally/autocross/daily drive engine
build up WITHOUT having to conform to ANY sanctioning body rules...this is
just the 'build the best' kind of thing. To make it interesting - let's
but a $6000 US cap on the modifications - parts only!
Buy Stock for $4.
No Minimums.
FREE Money 2002.
http://us.click.yahoo.com/BgmYkB/VovDAA ... /XoTolB/TM
Bench racing - optimum CR for Turbo
I know people that run 9.0:1 on 20+psi on 2.0 engines... Gives better
off boost response
-----Original Message-----
From: Rabin James [mailto:rabinjames@sk.sympatico.ca]
Sent: Thursday, March 28, 2002 4:32 PM
Subject: [BC-BFLegacyWorks] Bench racing - optimum CR for Turbo
Hi all,
ideal engine rebuild specs for the 2.2 L inline-4 in the 505 Turbo.
would be neat to compare an inline 4 against the boxer 4 in terms of
ideal engine build spec.
The one site had a guy totally rebuild the Suby 2.2 T with custom JE 9
:1 pistons for his plane...any thoughts on the pros and cons of running
a high compression high boost (13 psi) motor?
psi)? I know peak power is higher with the latter, but what about
driveability?
engine build up WITHOUT having to conform to ANY sanctioning body
rules...this is just the 'build the best' kind of thing. To make it
interesting - let's but a $6000 US cap on the modifications - parts
only!
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Buy Stock for $4.
No Minimums.
FREE Money 2002.
off boost response
Hi all,
driveability?
only!
Buy Stock for $4.
No Minimums.
FREE Money 2002.
