NEW Rear speakers working, then stopped
robbcolecrabtree
Post by robbcolecrabtree »
So I installed some new rear speakers in the wagon. I checked them as I was installing them and everything was fine. I got both sides in, they sounded good. Then I put the plastic covers back on, everything was tightened down, and I put my tools away, then..... No sound out all. It's like when I put the plastic covers on, and put my tools away, my speakers went on their union mandated break. Not sure what to do. I am going to go back in and check wiring, but does anyone have any ideas. Thanks for the help.
94 Legacy Turbo - SOLD!
04 WRX - SOLD!
07 STi - Couldn't ask for more in a car
robbcolecrabtree
problem solved. speaker was barely grounding on fuel tank side. phew
04 WRX - SOLD!
Just curious why would your speakers be grounded?
magicmike
Post by magicmike »
If you are in fact grounding your speakers to chassis I suggest fixing that before you blow up your amp in your head unit. Radios have not been wired like that for about 30 years now...
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Binford
Post by Binford »
I believe he meant that one of the speaker terminals(non insulated connector) was shorted to ground on the expansion tank that sits under the speaker in the wagons. A simple rotation of the speaker solves this.
BSOD2600
Post by BSOD2600 »
Binford wrote:I believe he meant that one of the speaker terminals(non insulated connector) was shorted to ground on the expansion tank that sits under the speaker in the wagons. A simple rotation of the speaker solves this.
I had this problem in my TW too. Ended up putting a layer of duct tape under the speakers terminal area so there wouldn't be any contact.
'11 WRX Limited
'94 TW | R.I.P.
